Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura Integra
Register Forgot Password?
Search
Welcome to Honda-Tech!
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today!
submit to reddit
Old 12-16-2006, 08:04 AM   #1
int3gra07
* B A N N E D *
Garage is empty, add now
iTrader Rating: (0)
Default how do you replace cam seals (Plural)
Not the distributor side. The inside of the engine. I need a step by step all the from Top Dead Centering from tightening bolts to spec. Thanks
int3gra07 is offline   Reply With Quote
Old 12-16-2006, 08:09 AM   #2
lVlemphizStylez
lVlemphizStylez's Avatar
iTrader Rating: (0)
Send a message via ICQ to lVlemphizStylez Send a message via AIM to lVlemphizStylez
Default Re: how do you replace cam seals (int3gra07)
do you mean valve seals??? Do you have the tools for this??
__________________
JustinKlemFag-I-Take-It-In-The-Ass has got to be the gayest moderator on TI
Team-Nazi.net FTL
lVlemphizStylez is offline   Reply With Quote
Old 12-16-2006, 08:30 AM   #3
mstolars
mstolars's Avatar
iTrader Rating: (0)
Send a message via AIM to mstolars
I think he means the 2 seals that are behind the cam gears. Changing those is pretty straight forward. Use a guide on changing cam gears to get the gears off properly, then just use a pick to remove the seals....that's pretty much how I changed mine. Don't forget a small ammount of hondabond on the outside of the seal to prevent leaks. Good luck, took me about 2 hours to change mine out....only had to change one though(I could easily tell which one is leaking) Click the image to open in full size.
__________________
'96 Acura Integra GSR-T
'08 Acura TSX
mstolars is offline   Reply With Quote
Old 12-16-2006, 08:32 AM   #4
lVlemphizStylez
iTrader Rating: (0)
Default Re: how do you replace cam seals (mstolars)
Quote:
word I thought he meant valve seals because the two on the Cams were pretty easy to decipher...This will require untensioning and retensioning the timing belt though...So look up on how to do that..There are a few different methods (and the tensioner is self tensioning device...I usually tighten the tensioner bolt a little bit...Rotate crank until I feel the belt get real stiff then fully tighten it and rotate the crank around some more until I have my desired tension (that's assuming your tensioner is good, if its going bad youll have to Coat Hanger it or remove the lower cover and manually pry with a screw driver to create the tension)
__________________
Team-Nazi.net FTL
Old 12-16-2006, 10:24 AM   #5
PatrickGSR94
1994 Acura Integra
PatrickGSR94's Avatar
iTrader Rating: (1)
Send a message via AIM to PatrickGSR94
The oil seals behind the cam gears do not get Hondabond. The plug on the other end of the exhaust cam does get Hondabond when installed.
__________________
Please do not PM me with technical questions. Create a thread in the appropriate forum.
H-T OG member #8927 class of '02 ● Koni + GC InstallHID retrofit club
member #0001
PatrickGSR94 is offline   Reply With Quote
submit to reddit
Tags
96, accord, cam, camshaft, change, gear, gears, honda, integra, leaking, plural, replace, replacing, seal, seals, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Emails & Contact Details
